linking single cells to AutoCAD LT
I use AutoCAD 2002 LT.
I am preparing a residential sub division plan and during the design development, most of the numbers on the drawing will be modified several times.
Examples are lot and building elevations. Every residential lot will have building elevations, corner and mid lot line elevations. For adjacent lots the corner and mid lot elevations will be the same along the common boundary. There are other relationships between the lots, for example adjacent building elevations are related and governed by the slope of the street.
I calculate these elevations in an excel spreadsheet. That part is not a problem. What I want to be able to do is automatically update the numbers on the drawings when I change the design. I will be trying several different combinations of street slopes and drainage layouts to determine the best fit. I can change these numbers on the spreadsheet automatically, just not on the drawing. In the past I have entered these values by hand and spent many hours checking only to discover errors in the transcription after checking.
I downloaded a demo copy of xl2cad from www.dotsoft.com but cannot enter a single cell value or update it automatically.
Is what I want to do possible with this product?
Is there a different product that will do this?
Rick Kitson MBA P.Eng
Construction Project Management
From conception to completion
www.kitsonengineering.com
RE: linking single cells to AutoCAD LT
Vladimir Michl
For some reason I had a lot of trouble with layer control in viewports. When I used the vplayer command to turn off layers with ole objects that I did not want shown in the viewport I could not select the objects. I had to redo all the OLE insertions onto a separate layer and type the layer name into the vplayer dialogue.
I also had a lot of trouble formatting the display/printout. I had one viewport rotated 90 degrees to the model and could not get the ole objects to print out. I opened the excel spreadsheet and turned the text in the cells 90 degrees and resized all ole objects and was able to get something that worked.
However in the on screen display the text in the OLE boxes is upside down, on the page the objects are right side up.
