API 661 Mechanical Design of Fin Fan Exchangers
Hi all,
I am looking for some specific guidelines for the design of API 661 Fin Fain heat exchangers.  The design of the header boxes must now comply with additional requirements as listed in API 661,2001, clause 7.1.6.1.3, & 7.1.10.  The design of the header boxes for internal pressure is relatively easy using ASME Section VIII, Div.1.  I am looking for advice on the design of all the other things mentioned in the clauses but not covered in the ASME Code.
Thank you.
John Fogg
RE: API 661 Mechanical Design of Fin Fan Exchangers
dont have API661..want to tell me what the requirements are?..AYBEE
