hi friends, could you give me some
hi friends,
could you give me some hint or idea on how to consider the frequency of the heat recovery wheel into dynamic model of the wheel and into total heat transfer coefficient?
appreciate your reply.
thanks
thanks
RE: hi friends, could you give me some
i'm going to use simulink to simulate working process of a ventilation with Heat Recovery Wheel(HRW), as to the HRW, i want to know how the response of the output temperature vary with the change of the input frequency of the wheel.
thanks friends
