UG-45(b)(2), ASME BPVC Sec VIII, Div 1
Does "...by using the external design pressure as an equivalent internal design pressure..." here means trE = (PE/P)*tr (as we always can calculate tr easily)? Where, trE - Required thickness based on external design pressure; PE - External design pressure; P - Internal design pressure; tr - Required thickness based on internal design pressure.
RE: UG-45(b)(2), ASME BPVC Sec VIII, Div 1
So if your external pressure is 15 psi, then you would use 15 psi in the shell (of head) thickness calculation in order to determine the minimun nozzle thickness.
trE = (PE/P)*tr
Where, trE - Required NOZZLE thickness based on external design pressure; PE - External design pressure; P - Internal design pressure; tr - Required SHELL/HEAD thickness based on internal design pressure.
esf has the correct answer.
prex
http://www.xcalcs.com
Online tools for structural design
