Viscosity vs Pressure Drop
Does anyone know a good formula for pressure drop of Hydraulic Fluid thru orifice vs viscosity of fluid and dia of orifice?
RE: Viscosity vs Pressure Drop
Crane Technical paper 410 has formulas for this.  Essentially, they have charts for the discharge coefficient as a function of beta ratio and Reynold's number.
This is still a grey area in chemical engineering especially for relief system design and inlet/outlet pressure drop calculations.  Go to www.diers.net and choose software.  Download the Free Mach II Reader and Regression Tool and also both the Safety Valve and Pipe benchmarks.  You can look at over 200 examples of safety valve(orifice) and piping calculations. Several include high viscosity fluids.  DIERS has done the most work in this area of modeling high viscosity systems.  DIERS is a user Group under the American Society of Chemical Engineers.  The Mach II Reader is free and comes with a very helpful User Manual which is also a great training manaul.
Have fun.
Hopefully the hydraulic fluid doesn't suffer any physical change when passing through the orifice. Have a look at Perry, the chapter dealing with concentric measuring orifices. It may help you to build your own formula for the permanent pressure drop (after, say, 8 pipe diameters), knowing flow rates, Re, orifice and pipe diameters and orifice edge whether round or sharp.
The permanent pressure drop, %, through a flow measuring orifice has been given by
104-32 beta-60 beta2
The formula would apply for beta values in the range of 0.2-0.8 .
