Company Publishes Ethics Guideline
Things are looking up. My company just put out an ethics guideline that makes it easy to report questionable practices 24-7 without ident. Complaints are handled by a third party and reported for resolution by higher management.
RE: Company Publishes Ethics Guideline
Many years ago I had experience with a boss who perpetrated the most unethical scheme imaginable. A project I was managing turned up a supplier that I didn't recognise. Material shipped to my attention was tagged by company X. It turned out that company X was a ghost intermediate company managed by the boss to siphon off money spent on the project.
I talked to others about this, and they said that was nothing. We got into a "Can You Top This" discussion. The specialty of Plant/Facility Engineering is notorious for abuses. One power plant executive had a steel outbuilding installed on his property by plant personnel at company expense.
Can you top this?
The big issue is whether the guidelines are adhered to and whether the management structure is truly motivated to enforce the ethics guidelines.
Even Arthur Anderson had both internal and external ethical guidelines that it violated.
TTFN
You can write all the ethics guidelines, document, memos, etc and they will accomplish very little. If you lack the personal ethics/morals/integrity that is required to do the job, you will have no problem not adhearing to a sheet of paper.
I agree with IRstuff, if management does not strictly enforce practices which violate company policy, then why should it expect employees to. Biggest problem is that it is often management that is violating the ethics policy, not the general employee.
Ethics can not be enforced... it is a part of one's character. If you are unethical to begin with, then there is nothing that can be done to change that.
jetmaker
