mechanica - is it possible to "view max"with "capping surface&quo
I am running Pro/MECHANICA on a complex part with some internal areas that are difficult to view. I can create a "capping surface" or a "cutting surface" to view these regions, but then I an unable to use "view max". I know you can zoom in on a particular location and then change the legend values, but that is very time consuming.
Is there a way to display the maximum values after creating a capping surface?
RE: mechanica - is it possible to "view max"with "capping surface&quo
ym
