Experience with Distributed Temperature Sensing (DTS) on power cables
Has anyone had some experience with using DTS systems to monitor power cables, particularly at higher voltages? I want to find some companies that supply the equipment, apart from SENSA/York in the UK. I have found a couple of others (Hitele, Optech) but I want to find out if there are other companies with units in the field already.
Also, what your experience has been to date. From what I've heard so far, cable temperatures seem to be coming back as quite a bit cooler than predicted by modelling?
Finally, what about location of the optical fibres for the temperature sensing. We've tried putting it in tubes laid up with the copper screen wires on 132kV single core cables, and it creates a lot of problems at the joints, so we are thinking about running them against the side of the power cable - either as a normal optical fibre tube, or in a larger tube into which the fibre is blown - permitting later replacement as the fibres age.
Any comments much appreciated.
RE: Experience with Distributed Temperature Sensing (DTS) on power cables
Dennis Carr
DCarr@slb.com
(713) 253-0839
Try Optiphase in Van Nuys, CA
http://www.olex.com.au/pdf/dts.pdf
http://www.engcom.com.au/publications/eea2000_dts.pdf
http://www.sensa.org/index.html
etc. for more info
