RBMware Trend Issue???
My business just recently upgraded to RBMware for vibration analysis. My issue, along with fellow co-workers, is that when using the multiple trends feature. When viewing a trend and you use the quik tabs on the right of the screen to switch to a Spectra,and then switch back,when you switch back, the software factors in machine speed and the trend goes to &*^$....you then have to back out to the main menu. Go back into Multiple Parameters and uncheck Machine Speed....but as soon as you switch to a spectra and then back it factors in the Mahine speed again. This is rather annoying and CSI's website offers no solution to change that software to not factor in machine speed..I am well versed in the old software but this new software is a little beyond me right at the moment. Any help or ideas would be most appriciated.
RE: RBMware Trend Issue???
Did you try this software alongwith the database of your system in another computer. Could be the problem of hardware support. Sometime it happen. Sometime the software does not support the hardware you are using. Or the OS (operating system). Try this may be it could help.
khan912
Patrick
