Noise filter transformers
Hi, how you guys are doing?
Well, our client(Marine conditions) wants to use noise filter transformer(of capacity 1.5KW) for receptacles of a computer, work station for monitoring system and a printer. Three receptacles (of double type)each of 250V, 120VA are used for those three. From 220V distribution board is feeder to transformer, to which 3 receptacles(double type) are connected in series. Guys, suggest
1. For what all purposes(we were told as noise filter) these transformers can be used?
2. How many transformers with 1.5KW(converting KVA) are required, taking 800VA for computer & 500VA for printer(work station no idea)?
3. Suggest any vendor for purchasing the transformer, also suggesting some weblinks to have a fundamental knowledge of transformers used for all purposes.
Also suggest, if anything is wrong.
