Concete Expansion Joints
I always think about control and construction joints in concrete slabs and walls but not expansion joints. When are you supposed to put in expansion joints?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Concete Expansion Joints
joints they cut into concrete roads ?
Joints should be prepared properly and as follows: Thoroughly clean dry joints using compressed air. This will remove dirt, dust, and other foreign matter. The air compressor shall have:
1. Minimum rated capacity of 100 psi
2. Sufficient hose for continuous cleaning operations
Here is a quick link to joint sealing: ht
Lutfi
www.cdeco.com
