COPPER AND ALUMINUM
COPPER AND ALUMINUM
COPPER AND ALUMINUM
I have aluminum wire lugs and wnat to connect 6 AWG wire that is copper.  Is it ok to combine the two materials.
RE: COPPER AND ALUMINUM
Depends on the UL listing of the lugs.  If they're listed or stamped "CU/AL" or similar, then you're set.  If they're not listed or stamped as such, then you're out of luck.
