Carrier Water Guidelines
What conditions typically dictate the use of carrier water in chemical feed applications for Municipal Drinking Water Treatment?
RE: Carrier Water Guidelines
Convenience?
The main purpose for using carrier water is to increase the flow velocity of chemical line. It helps to:
- avoid settlement in pipes (i.e during lime water feeding)
- increase flowability in pipes (i.e. during polymer feeding)
- reduce the time-lag between the dosing pump and dosing point
