Ball Bearing Number Comparison
Dear all
 Anyone please suggest  me about  the resource of the AFBMA standard and Bearing number comparison between AFBMA standard and Manufacturer (such as SKF).
 Thanks in advance for your kind.
  Prasit P.
RE: Ball Bearing Number Comparison
It isnt free, but it should give you all you need, look here:
http://www.sourceindex.com/default.asp
I also have a brg. interchange manual that came from Bearing Headquarters, a very good source, though mine dosent list the AFBMA standard.
Also try a Google search on bearing interchange.
Hope this helps!
