Exporting Assemblies as STL
Hello Solid Edge users,
I have some solid edge assemblies that I want to export in .STL format. Can this be done? I see that parts will export into STL just fine, but I really need to work at the assembly level.
Thanks.
Mark Downing.
Thanks.
Mark Downing.
RE: Exporting Assemblies as STL
Saving as Parasolid, Iges etc. will work also.
Pekelder
The other option would be to open a new part and Insert a Part Copy of your assembly. Many times this fails as solid geometry, but usually works as construction if the surfaces are all you need.
--Scott
