edrawing functionality in solidworks?
edrawing has some awesome things like show transparent and easy move of parts then hit the home button then it all goes back together. is there a macro or other routine written that will give me these types of functions in solidworks assembly environment? I really want to just make parts go semi transparent at the click of a button instead of the buired color structure for picking and viewing etc.
6 month newbee
thanks for the great info here! jh
RE: edrawing functionality in solidworks?
Do you have subscription support?  If so you can go out to the subscription area on the SolidWorks website and download a macro that does this.  It is found under the 3D Model Library, API, Miscellaneous.  If you do not have subscription support I could email it to you.
BBJT CSWP
Wow, thanks for the fast respose. No, we don't have subscription support here, running 2003 office though. I will take you up on your offer. Is there alot of stuff available that would make a brief subscrition worth having?
Thanks,  jh
johnh@autoapp.com
No problem jh.  It is on its way.
BBJT CSWP
