Palladium Analysis -UV/Method
I am looking for an alternative analysis for Palladium concentrations (in an acidic matrix) that are around 12ppm. My current method is AA but due to other metals I analyze, I am concerned that I am plating up the internal parts of this instument. The direct UV/measurement at this low level is detectible at such a low wavelength that it is not stable. Can the Palladium be chelated with an NH3? If so, should it be saturated and what wavelength range should I scan?
