standard file selection dialog boxes
Autocad 2000i
Standard file selection dialog box.
Views.
We want "list" to be the default not "preview".
how do we change it?
RE: standard file selection dialog boxes
View setting in Select File dialog box is not retained
Published date: 2001-12-06
Applies to:
AutoCAD® 2002
AutoCAD® 2000i
AutoCAD® 2000
AutoCAD LT® 2002
AutoCAD LT® 2000i
AutoCAD LT® 2000
Issue
On the File menu, you click Open. In the Select File dialog box in the Views drop-down list, the view type always reverts to List in a new session of AutoCAD, even after you changed the view type to Details
Solution
This is as designed; there is no way to retain the setting.
I believe the "LIST" option is THE OPPOSITE toggle for "DETAILS".
Preview will always occur whether it's set to LIST or DETAILS.
ALSO ,,,,
By default, AutoCAD is to LIST/ PREVIEW.
BUT WHY?
Would you want the preview window off?
