Importing multiple coordinates and depths
Hi all
I work in the offshore industry and have been sent some data that I want to import into autoCAD LT . I admit to being pretty new to autocad so need a laymans introduction into importing from a text format straight into autocad without having to manually insert them by hand. I know how to do that bit but it would take about 3 weeks to insert all the data I have been KINDLY sent! Anyone out there willing to help and give a novice a hand?
The format is in Eastings and Northings and Depths, basically contour lines wanted as the end result.
Cheers
Mark
Cheers
Mark
RE: Importing multiple coordinates and depths
I have Land Desktop and can import the northing, eastings AND ELEVATIONS in about 2 seconds build a dtm and generate contour in about 5 minutes. I would be more then happy to do this for you. I am pretty slow today THANK GOD!
If you send me the file I will send you the dwg with the points and contours in it back to you in about 10 minutes.
That's got to be good for the budget and you can leave early:)
If you want the assistants here is my e-mail address
Cathrine.Strollo@FPAWWW.COM
If so then you can import YOUR LIST of coordinates into a SCRIPT file and run that through AutoCAD.
See this thread below.
Thread555-45632
Hope that helps.
Thanks again
Mark
Power Point is a different question. It's better to meke a new thread....
But anyway, the easiest way is to take copy&paste (white screen)
Lothar
Win NT4.0 (SP6),
ACAD 2000i (SP2), ADT 3.0 (SP3),
ACAD 2002, ADT 3.3,
OCÈ 5200
