PAM Winding Connections.
Dear Fellow Members/Readers,
I'm looking for suitable websites or literature that could provide details of PAM Winding connections (two speeds, one winding) for medium and large Three Phase Electric Motors.
If there is anyone connected with PAM Windings in Three Phase Electric Motors who has knowledge of where this information will be available, your help will be most appreciated.
Many thanks,
r2d2.
Many thanks,
r2d2.
RE: PAM Winding Connections.
http://www.its.bldrdoc.gov/fs-1037/dir-029/_4233.htm
http://www.ece.utexas.edu/~bevans/courses/realtime/lectures/15_Analog_PAM/
http://www.ieee-occs.org/56k/sld020.htm
http://robotics.eecs.berkeley.edu/~sastry/ee20/modulation/node6.html
etc. for more info
Also, contact manufacturers of ac motor drives, e.g.
Siemens, ABB, GE, Robicon, Toshiba, Hitachi, Alstom, Square D, Cutler-Hammer, etc. for more info.
As a service center, I receive occasional requests for conversions from existing (standard) single speed motors to two speed. Depending on the request, I convert windings to the pole change type where convenient. Alternatively, I provide two separate windings for the respective speeds, providing stator and rotor slots permit (the change).
The PAM winding configuration would help avoid two separate windings as only one winding is used. I do not have a problem with designing the required turns and wire sizes to suit respective KW outputs. The problem I have is establishing the COIL PITCH, NO: of GROUPS, NO: of COILS per GROUP and the CONNECTION SEQUENCE for the PAM connection to suit various stators and the number of slots they contain.
Any further help or suggestions are welcome.
Thanks once again.
r2d2
being a service center and are activly involved with electic motor repair you are able to join an organisation called e.a.s.a.
they have for sale a re design programme on disk this covers p.a.m. type windings along with connection diags.
note:- p.a.m. type windings are complex and basic 3 phase connectins do not apply.
good luck and regds
e.a.s.a can be found at www.easa.com.
regds
