plot cross sections with coordinate
i would like to find out how to transfer coordinates from excel to autocad which showing line and numbers for coordinate (x,y) on each point on autocad drawing.
RE: plot cross sections with coordinate
many ways, however, most require saving the file in a comma delimited format or other format in an ascii file.  you can then use a simple lisp routine to insert the points.  most engineering design packages also have routines to do this
Cohong,
I have a lisp program and block that might do what you want.  Send me an email and I will send it to you.  murrisonenvironmental@cox.net
Scott
