Draft Analysis in V5R10
We have just installed V5R10 from V5R8 and are having trouble trying to use the Draft Analysis tool. Does anyone know how to set the die pull to somthing other than the Z-Axis? We design parts in car position and generally have the die draw to be down x-axis.
Hopefully this is a simple step. If not, this is a very cumbersome tool and could cause parts to be designed with dielock situations.
Mark L.
ValeoSylvania
RE: Draft Analysis in V5R10
Alain.
