Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...(I) have been able to get my problems solved from past messages and also new posts that other users have responded to promptly..."
Geography
Darra (Automotive)
10 Apr 03 2:07
Dear Co-profesionals.
I have a inquery about a suitable plastic or foam material that is used as a packagin material for sensitiv equipment. This packaging have to withstand outdoor condition such as dust, rain, acid-rain, temperatures between -40 C and +70 C.
If you have any sugestions of materials, coatings and or manufacturing processes, please let me know.
I appreciate any input.
Thanks!
Darra!
Helpful Member!  plasgears (Mechanical)
10 Apr 03 12:41
Jet engine handlers ship in steel clam shell casings. The plastic equivalent would be rotomolded flanged half boxes. Clamp or bolt the flanges together. Provide for fork lifting shape on bottoms.
patprimmer (Publican)
11 Apr 03 1:43
What size and weight are the goods to be packaged.
Can it be done with a tough shell and a foamed interior
pat
Darra (Automotive)
11 Apr 03 5:46
Hi guys!
Thanks for your replays so far. Here is more info...
The size of the equipment that need to use this packaging system varies becouse is made of diffrent components that have to be placed inside a hard shel box in some type a fome or type of plasit that can protect them during transportation. The Shell box is no larger then 1x1 meter.
I was thinking of either some kind of polyurethan or polyeten. Are any of this 2 materials resistent to water, dust and sun (UV)? Are they suitable at all? What manufactoring process can be used?
What do you guys thinsk?
Plese come with suggestions..
vahanyan (Mechanical)
15 Apr 03 19:03
You can wrap it with plastic shet and then spray with liqiud foam on top of it. The foam is sold in hardware stors and used for outdoor isolation purposes (around the window frame prior to installation).
Soupcat (Mechanical)
16 Apr 03 9:54
What is your annual unit volume requirement? And what is the strength requirement, weight of parts being transported etc.
Kieran
www.moulddesigner.com
ornerynorsk (Industrial)
22 Apr 03 14:18
Heat sealed heavy (10 to 20 mil) poly bags with a voc wrap and dessicant will take care of most problems. Rough handling will require some form of external crating.  Most machine tools are shipped this way, remaining packaged for up to several months.  You could try to find a happy medium in a standard container, but that means shipping back empty, lots of wasted space etc.
Close Box
Join Eng-Tips® Today!
Join Us             Close
