GYPSUM BOARD SHEATING FOR WOODEN STUDS
Is Gypsum Board Sheating Allowed For Wooden Studs? If it is, where can we get the shear capacity.
In UBC 1997, Values for allowable shear load of Gypsum Board Sheating with corresponding nail spacing is only for metal studs, thhere is no value for w00d studs. tnx
RE: GYPSUM BOARD SHEATING FOR WOODEN STUDS
Gypsum Sheathing Board 4x8x1/2" 11 ga Screw unblocked 7" oc panel 10oc intermediate shear capacity=100 plf
Gypsum Wall Board
1/2" thk 5d cooler nails
unblocked
7" oc panel Edges 10oc intermediate support,
4" oc panel Edges10oc intermediate support,
shear capacity=125 plf
blocked
7" oc panel edges 10oc intermediate support,
4" oc panel edges 10oc intermediate support,
shear capacity=150 plf
5/8" thk
blocked 6d cooler nails
4" oc panel 10oc intermediate support,
shear capacity=175 plf
blocked two layer
Baseply 6d faceply 8d cooler
Base 9" face 7" OC panel edges 10 oc IC
Shear capacity=250 plf
also listed in SSDT 10-93
As to what Taro said about not relying on gypsum. Yes, plywood is stronger and is a ductile type of failure, but gypsum is stronger than most people(including the code) give it credit for. The reason the values are lower is because it is a brittle failure mechanism.
For high siesmic regions gypsum is prohibit from being used to resist earthquake forces anyway. For wind controled lateral forces it is fine material. Keep in mind though the aspect ration cannot be reduced from 4:1 like plywood can in lower siesmic zones.
