T.I.G. Welder or Welding
hi,
whenever its mentioned T.I.G. Welder or Welding, can someone
tell me what does the initials T.I.G. stands for ?
hope to know.
regards,
bourne
hope to know.
regards,
bourne
RE: T.I.G. Welder or Welding
Tungsten Inert Gas welding
(ie. an arc is struck between a tungsten electrode and the metal surface to be welded)
The process can be performed with or without a filler metal.
Gas shielding is required.
Hope this helps.
bk
thanks for your precious help, buddy.
bourne
If you search "TIG Welding" and "GTAW Welding" on google you get 20,200 and 791 hits respectively.
W. Baker
Blacksmith
rarely is weld porosity (gas inclusions an reacted components) desireable in modern welding as a joining process. it may be used in various flame spraying methods but not in joining.
gases that combines with the weldment are generally used because of cost rather than the quality of the weld.
