Steel Connections: vertical and horizontal "play"
I am having a little bit of trouble developing a sense/strategy for where and when steel connections need vertical or horizontal slotted holes for adjustment in the field.... e.g. a steel brick hanger bolted/hung from a gussett plate from a beam above (vertical slotted hole in gussett??) and the brick angle (horizontal slotted hole?) which the hanger supports...
I know it's kind of a vague question and I have trouble articulating what I mean, but anything helps...thanks guys!!
-boo
RE: Steel Connections: vertical and horizontal "play"
Dear Mr. JBOO,
Pl. check the following minimum & maximum slot variations for a given dia of bolts.
Dia        Short Slot            Long slot
3/8"       7/16" x 5/8"          7/16" x 15/16"
1/2"       9/16" x 3/4"          9/16" x 1 1/4"
3/4"       13/16" x 1"          13/16" x 1 7/8"
7/8"       15/16" x 1 1/8"      15/16" x 2 3/16"
1"         1 1/16" x 1 1/4"     1 1/16" x 2 1/2"
The above dimensions , we have been following. Our team heads are very confortable with these kind of allowances.
