Burner Flame Safety
Burner Flame Safety
Burner Flame Safety
Five steel vats containing aqueous solutions are heated from below with individual 40,000 btu/hr drilled-pipe natural gas burners.  The burners are fitted with atmospheric mixers and manual shutoff valves.
What are the most simple but effective flame safety systems that can be adapted to these burners?  A brief description of the required components and possible sources would be appreciated.
Thank you for your assistance.
RE: Burner Flame Safety
Two safety devise could be considered:
Flame sensor, heat sensitive safety valves supply automatically cuts off then no flame is present.
Equipped with an Oxygen Depletion Sensor, a safety feature that shuts down the unit automatically if there is not sufficient oxygen in the room.
e.g. flame / hear sensor - thermocouple and switch as in gas water heaters for home use or anywhere else.
These people can offer you a flame monitoring/detection  system that may help you.
Credfeld Ltd
13 HYS Port Hamble
Satchell Lane, Hamble
Southampton
SO31 4QD  (Road Map)
Hampshire
Tel: 023 8045 4359
Fax: 023 8045 4399
Internet: www.credfeld.uk.com
Managing Director - Simon Vine
Technical Director - Bill Reynolds
Products and Services
Combustion Systems
Flame Detection Equipment
Gas Burners
Ignition Systems
Oil Burning Equipment
