MS Project 98 SR-1 & Windows 2000 Problem
I am running Microsoft Project 98 SR-1 on Windows 2000.  When I try to do a "Save as" from the File menu I get an error message instead of the "Save as" dialog box.  The error message is: "There is not enough memory to display the Save dialog box."  In the error message dialog box I am prompted to save the project files as a temp (.tmp) file.  When I go into Windows explorer and change the .tmp to .mmp I am able to open the project as per usual.
Anyone know what could be causing the error?
RE: MS Project 98 SR-1 & Windows 2000 Problem
hi gcaudill,
have you figured out the cause and resolution of this error message?  i have encountered the same and need desperately to solve so that i can print project.  help!
I have not found the cause of the problem.  Someone mentioned to me in passing that maybe it is because the installation CD was a copy of the original, but it's not to my knowledge.
Good Luck!
You probably already tried this but here goes:
Save the projects with your tmp extension. Then completely uninstall then reinstall the program paying special attention to any installation options that may be offered.
It's been a long time since I inatalled MS Project and can't remember if there are install options --- if I recall correctly there is a minimal installation and a normal or recommended install. Choose the recommended installation.
Hope this helps
ietech
