Replacing a resistance spot weld with a plug weld.
What is the best way of determining the proper size of a plug weld to replace a resistance weld in an assembly? Is it based upon the diameter of the spot weld electrode and the depth of the plug weld.
RE: Replacing a resistance spot weld with a plug weld.
Plug weld sizes are detrmined by the diameter of the weld in the plane of the faying surfaces.
