Mystery Component
Mystery Component
Hi there, I'm a computer engineer looking for some help with a PCB component.
I'm looking for a replacement component for one that has snapped, and was wondering if anyone knew where I could buy one, as it's from an existing PCB, it really needs to be identical to the old one, here are the specs:
Component: 10K surface mount slide potentiometer
Length: 35mm
Width: 8mm
Number of pins: 3
If you need any more info, post and i'll get back to you. Thanks in advance.
Length: 35mm
Width: 8mm
Number of pins: 3
RE: Mystery Component
<nbucska@pcperipherals.com>
