Viscous Damper - Rotary
Is anyone aware of a "rotary viscous damper" device that could be used to allow for rotation below specified speeds at low "drag" and would increase drag torque at higher speeds? I want to use this device as a safety feature on a motion control system. The motion is by a carriage (with drive motor) along a rail. If the drive shaft or gear (rack and pinion) of the drive motor fails (single point critical element) I want the viscous damper to retard the drop speed of the carriage assembly to acceptable levels.
MJVanVoorhis@Compuserve.com
RE: Viscous Damper - Rotary
Sounds like what you need is a continuous (unlimited) rotation hydraulic actuator. The only one I know of that would give you smooth motion at low rates, while backdriving, is the one that we developing (not available yet). If you have a high enough rate you may be able to use a hydraulic motor or a pump.
Have you considered a centrifugal brake (like a centrifugal clutch, only a brake) or an eddy current brake using permanent magnets? These may be alternatives to using hydraulics and would give similar operating characteristics.
You want to try a Viscous coupling, as used in 4WD Vehicle transmissions. They can be built to have varying torque characteristics against rotational speed, even to the point of locking-up completely. with the right set-up it is possible to have negligible torque at very low rotation, rising at a pre-determined rate as speed difference accross the coupling increases, the conditions under which they lock-up can also be specified. You don't need any external control, they are sealed, maintenance-free units, safe for use in hygenic processing (viscous medium is silicon fluid).
I worked a long time in research on these units, so if you need more info, get in touch...BTW, the also make good driveline vibration dampers....
Try Energy Kinetics Inc. in Illinois at (630) 357-3819. They carry a line of viscous rotary dashpots from a company called Kinetrol. Also have you tried AirPot Corp. in Conn.
