pulley tensions
pulley tensions
pulley tensions
we have the following formula for calculating belt tensions in a pulley system. is it correct?
         u'y
T1/T2 = e
T1 + T2= tension in belts
u' = co-efficient of friction/ 1/2 'V' belt angle for B
                               section belt
y =  theta= angle of lap
what is e? is it the button on the calculator or another variable
RE: pulley tensions
Yes, It is the "button on the calculator".
e is log base 'e' e=2.7182
                                 u'y
your equation should read T1/T2=e
Edson Campos
edsoncampos@earthlink.net
