low power/ high efficiency voltage regulation.
Has anyone had experience of designing high efficiency low power supply circuitry?
I want a circuit that supplies 3.8v Dc. For 95% of the time it should supply 1 or 2 mA but the rest of the time it must supply nearer 200ma with occaisional peaks at 1A or so,(duration only mS or so). This circuit is itself powered from batteries that supply a fluctuating voltage between 10v and 16v.
My current power regulation circuit as supplied by the manufacturer draws 10ma even with no load or application attached, so to extend battery life dramatically I need to bring down the no load consumption of the power control circuitry while the application is drawing less than 1ma in sleep.
I have looked at some Analog Devices Chips, mainly the ADP range.
Can any one advise what the most efficient device or method may be for this.
Any help or suggestions would be gratefully received
RE: low power/ high efficiency voltage regulation.
Efficiency is over 80% at all times with the new design. Self drain is in the low microamps, compared with the 10 mA you're seeing now.
