Fatigue Titanium Alloy
Would anyone be able to inform me where I can find fatigue characteristic info about Titanium 6% Aluminum 7% Niobium (alloy)? This is typically used in medical applications. In other words, i'd like to find out notch characteristics, endurance, surface def, etc specs. Thanks.
RE: Fatigue Titanium Alloy
"TIMETAL® 367 (Ti-6Al-7Nb) Titanium Alloy
Features: TIMETAL 367 is a dedicated, medium strength, titanium alloy for surgical implants. The alloy was developed specifically for the manufacture of femoral component items for hip prostheses. Its metallurgy is closely analogous to that of TIMETAL 6-4 but biocompatibility is improved with the replacement of vanadium by niobium.
Typical heat treatment for this alloy: Anneal at 700°C for 1 hour, air cool.
Data provided by TIMET.
Physical Properties Metric English Comments
Density 4.52 g/cc 0.163 lb/in³ Typical
Mechanical Properties
Tensile Strength, Ult. Min 900 MPa Min 131000 psi
Tensile Strength, Yield Min 800 MPa Min 116000 psi
(0.2% Proof)
Stress Elongation at Break Min 10 % Min 10 %
Reduction of Area 35 % 35 %
Modulus of Elasticity 105 - 120 GPa 15200 - 17400 ksi
Typical Fatigue Strength 500 MPa 72500 psi
(rotating bend; limit at 10^7 cycles)
Thermal Properties
Beta Transus 1015 °C 1860 °F
Another manufacturer is Allvac, An Allegheny Teledyne Company, whose alloy is
Allvac® 6-7 UNS R56700 Titanium Alloy
For more data on Ti-6Al-7Nb, contact either Timet http://www.timet.com/367frame.html
or Allvacc http://www.allvac.com/allvac/pages/Titanium/UNSR56700.htm
Rotating beam, fatigue strength at 107 cycles:
highly polished, 620 MPa
shot blasted, Ra = 1 micron, 580 MPa
corundum blasted, Ra = 3 microns, 500 MPa
oxygen diffusion hardened (40 microns) + corundum blast = 360 MPa
ODH + highly polished = 340 MPa
Probably the best place to find additional information is from the comprehensive Titanium reference Materials Properties Handbook: Titanium Alloys. The reason I say probably is because I can't remember for sure if this alloy is covered. You can obtain this book directly from ASM using the following link:
http://www.asminternational.org/Template.cfm?Section=Bookstore&template=Ecommerce/ProductDisplay.cfm&ProductID=11019
A good university engineering library should have this as well.
I've found quite a bit of literature on the Ti-6Al-4V alloy, but cannot find much on the Ti-6Al-7Nb alloy besides the basic mech. props as provided earlier in this thread (and thanks to those who replied earlier!)
367 is a dedicated, high-strength, titanium alloy with excellent biocompatibility for surgical implants.
Composition
Al 6.5-6.5%
Nb 6.5-7.5
Ta <0.50%
Fe <0.25%
N2 <0.05%
O2 <0.20%
C <0.08%
H2 <0.009%
Ti ~ Rem
Mechanical Data Typical
Tensile Strength MPa ksi) 1000 (145)
0.2% Proof StressMPa(ksi) 900 (130)
Elongation on 5D % 12
Reduction in Area % 35
Elastic Modulus GPa(Msi) 105 (15)
Ti-6Al-4V Grade 5
many aerospace engine and airframe components uses and also major non-aerospace applications in the marine, offshore and power generation industries in particular.
Composition
C <0.08%
Fe <0.25%
N2 <0.05%
O2 <0.2%
Al 5.5 - 6.76%
V 3.5 - 4.5%
H2(sheet) <0.015%
H2(bar) <0.0125%
H2(billet) <0.01%
Ti ~ Rem
Mechanical Data Minimal Typical
Tensile Strength MPa ksi) 897 (130) 1000 (145)
0.2% ProºF StressMPa(ksi) 828 (120) 910 (132)
Elongation Over 2 Inches % 10 18
Reduction in Area % 20
Elastic Modulus GPa(Msi) 114 (17)
Hardness RºCkwell C 36
Specified Bend Radius<0.070in x Thickness 4.5
Specified Bend Radius >0.070in x Thickness 5.0
Welded Bend Radius x Thickness 6
Charpy, V-Notch Impact J(ft lbf) 24 (18)
In all seriousness, I recommend you do the following:
1. Read the data sheet from TIMET that Ken posted earlier. The information regarding alloying, heat treating, and fatigue data that I referenced can be found there. I will post the link again:
2. Find a copy of Materials Properties Handbook: Titanium Alloys and see if Ti 367 is included.
3. Contact someone from Timet and/or Allvac. Timet will definitely be able to provide you with technical assistance regarding microstructure, fatigue, etc. I have received a lot of data from them in the form of technical papers and presentations with nothing more than an informal call to their technical center (Henderson, NV 702.566.4403).
And just as a clarification, I did not mean to include the word "cast" in my previous post. I was going in one direction and then changed the sentence, but forgot to delete "cast". The heat treatment applies to this alloy regardless of product form.
There seems to be one very important (potentially) factor which is missing here-unless I missed it in the refs. Even tho Ti is very corrosion resistant, the fatigue properties may well be affected by the environment-in this case salty water or whatever is inside us besides blood. <g>
You need to search out fatigue data for this alloy that was performed in a simulated human body environment.
