Allowable Stresses
Allowable Stresses
How to fix the allowable stresse for the following stress conditions, for mechanical equipment and pressure vessel ? The basis has to be realistic based on research findings since we cannot assume high factors of safety.
Tensile Loading
Compressiver Loading
Shear Loading - Direct Shear
- Torsional Shear
- Thread Shear
Contact Stresses - Surface Contact - Flat to Flat
- Point Contact - Ball to Flat
- Rolling Contact - Flat to Flat
It does not seem to be prudent to take the allowable stresses as per ASME for non-pressure containing members where only a pure mechanical load can be expected.
The allowable stresses recommended by the other texts seem to be too conservative/unrealistic. Hence a rational approach is desired. Will be thankful if some one could throw more light on this subject in detail.
Tensile Loading
- Torsional Shear
- Thread Shear
RE: Allowable Stresses
Contact ASTM, ASME, NASA and various universities to see if they have literature available that describes your loading and materials sufficiently to allow for safety factor reduction.
Tom Worthington
pworthi@astro.as.utexas.edu
