efficient power regulation and supply
Has anyone had experience of designing high efficiency low power supply circuitry?
I want a circuit that supplies 1ma at 3.8v Dc for 95% of the time powered from batteries that could deliver up to 12vDc and 5V DC depending on customer requirements. Occaisionaly when the application wakes up it will draw upto 300ma for several minutes with very short duration,(10ms or so) about 1.5A,(GSM pulses)
My present power supply circuit draws 10ma while the application draws less than 1ma and I need to extend battery life by at least 500% by improving the power regulation side of things.
I have looked at some Analog Devices Chips, mainly the ADP range.
Can any one advise what the most efficient device or method may be for this.
Any help or suggestions would be gratefully received
RE: efficient power regulation and supply
<nbucska@pcperipherals.com>
