Heat Exchanger suggestion for silicone polyester thermoset coatings
I'm looking for a heat exchanger to control viscosity through temperature. My concerns are solvent evaporation and resin system degradation.
Any suggestion would greatly be appreciated.
RE: Heat Exchanger suggestion for silicone polyester thermoset coatings
Without knowing anything about your process, I would propose a closed vessel with a heating or cooling coil as requirements dictate, and with an agitator to help keep temperature variations of the material you are trying to control within the vessel to a minimum.
