steel and concrete composite section
Hi, all. I am doing a dynamic modelling of a building. SOme of the beams are made up with 2 W-sections side by side encased in concrete. ANy suggestion on how to model the equivalent section? I suppose the total area of section can be calc by Ac+As(Es/Ec), but what E do you use? Ec or an equivalent E? how would you calculate the equivalent E?
Thanks in advance for all suggestion.
Peter Lee
www.neillandgunter.com
Peter Lee
RE: steel and concrete composite section
Hi n9yz
Correct me if I am wrong as I am no civil or structural engineer but for a beam of two materials I would proceed as
follows:- Assuming that the steel and concrete are connected
ridgidly together the bending moment:-
      M=Mc + Ms
      M= Ec*Ic/(R) + Es*Is/(R)
      but Es/Ec = m = modular ratio
      M= (Ic/(R) + m*Is/(R))*Ec
      divide thru by R
       M=(Ic+m*Is)*Ec/R   and Ec/R= fc/y
      : M=(Ic+m*Is)*(fc/y)
      where fc=stress
            Is,Ic= second moments of area for steel
                   and concrete beam.
             R = radius of curvature of beam
             Ec,Es = modulus of elasticity of materials
              y = distance to neutral axis
     By using this method I have found the equivalent
     second moment of area of a complete concrete beam by
     using the modular ratio and converting the steel part
     into a equivalent concrete part.So you can now
     calculate stress using Ec only. Alternatively you can
     turn the concrete portion into an equivalent steel beam
     if you desire again using m however the formula would
     look like this:-
       M=(Ic/(m))+Is)*(fs/y)
     hope this helps
     regards desertfox
