RSLinx to VB using OPC
I have just started a project which requires me to read data from a PLC5, format the data and put it in a DB. the last part of this is not a problem but i need a tutorial on geting the data from the PLC via OPC. Does anyone knows where i can get some info on this?
RE: RSLinx to VB using OPC
See thread on this board from Sept. 26 titled "PLC and VB Interfacing using RSLinx", it looks like what you are looking for.
Also, maybe you should consider RSSql for easy setup.
