Digital Phase Adjuster Circuit
I am currently working on a college project (on PSK)
In order to decode a PSK 'transmission', I need to be able to 'correct' the phase of a squarewave signal(f=4500Hz).
Is there a simple circuit I can use which will vary the phase of such a signal ( 0 - 180 degrees)?
RE: Digital Phase Adjuster Circuit
Ten years ago I programmed a Xilinx Field Programmable Gate Array (FPGA) to variably delay the phase of a 2400 Hz tone 0-180 degrees with 1 degree resolution. Very precise and repeatable. A microcontroller or DSP could do this too, or use a tapped digital delay line.
If you must stay analog, try a Phase Locked Loop (PLL) IC.
Good luck!
Kevin VanZuilen "KevinVZ"
http://www.planetee.com/planetee/servlet/DisplayDocument?ArticleID=389
http://www.mathworks.com/access/helpdesk/help/toolbox/commblks/simref12.shtml
http://www.mathworks.com/access/helpdesk/help/toolbox/commblks/simref12.shtml#611854
http://www.mathworks.com/access/helpdesk/help/toolbox/commblks/mfskdemodulatorbaseband.shtml#436894
http://nmsp.gsfc.nasa.gov/tdrss/mod.html
http://www.physics.udel.edu/wwwusers/watson/student_projects/scen167/thosguys/psk.html
http://www.kender.es/~edu/psk31.html
http://www.ac6v.com/opmodes.htm#PSK31
http://www.cs.ucl.ac.uk/staff/S.Bhatti/D51-notes/node12.html
http://www.delphion.com/patlist?&xcl=375&ea=1
(above include various related patents)
Demodulation aspects:
http://www.mathworks.com/access/helpdesk/help/toolbox/comm/ddemod.shtml
http://www.ednmag.com/ednmag/reg/2000/06222000/designideas.htm
http://www.uspto.gov/web/offices/ac/ido/oeip/taf/def/329.htm
for more info and specifics to your task. It appears that more info is needed whether your square wave is supposed to be phase shift self-correcting or phase shift compensating for a phase shift keyed message phase 0-180° phase variations and how fast variations. The phase shift may vary in time.
