Testing membrane
Testing membrane
Can some one suggest a color molecule of about 0.2 microns size, and which is water soluble? I want to use this in solution on our microfilter(cut off at 0.1 micron) to see if it works properly. This could be routine check.
RE: Testing membrane
http://www.handprint.com/HP/WCL/pigmt1.html#particlesize
You should be able to get these pigments at most art stores and any university art supply. All of them are water based and relativly non-toxic. Make sure to stir them completely to break up any settling and floccing that may have occured.
Hope that helps.
