structure and array
structure and array
i have created 2 array (member and video). both are strcture. i have 3 text file storing the data needed.
(members.txt, videos.txt and loans.txt)
file :
member.txt
12:Ian Richards:Africa:33 Beach Street:Hervey Bay:4655:(07)4567 8901
34:Yan Li:Secret:13 Mockingbird Lane:Mysteryville:7654:(03)2345 6789
56:Fred J. Bloggs:Kidman:45 Blue Gum Parade:Toowoomba:4250:(07)4641 3456
video.txt
123:Armagedon:145
234:2001 A Space Odyssey:156
456:Star Trek Generations:178
567:Apollo 13:135
789:Blade Runner:187
890:Matrix:144
loans.txt
123:12
789:34
890:12
coding:
typedef struct member{
char id[3];
char name[20];
char password[9];
char address1[20];
char address2[20];
char code[5];
char phone[14];
char video[3];
} member;
typedef struct video{
char vcode[4];
char title[25];
char runtime[4];
char memberid[3];
} video;
how can i store all the video that is loan by one same member????
Having 123:12 and 890:12. i am only able to store one video number into member 12. Please help.
How should my member structure be change??
file :
member.txt
video.txt
123:Armagedon:145
567:Apollo 13:135
890:Matrix:144
loans.txt
123:12
789:34
890:12
coding:
char id[3];
char name[20];
char password[9];
char address1[20];
char address2[20];
char code[5];
char phone[14];
char video[3];
} member;
char vcode[4];
char title[25];
char runtime[4];
char memberid[3];
} video;
RE: structure and array
In the loan file, you would have one line per member-video association; there would be no video association in the member structure, nor member association in the video structure.
With this solution, the member file will be changed only when a new member is added, or when a member is removed. The same way, the video file will be changed only when a new file will be added, or when a file will be removed from the inventory.
Hope it helps!
