Bellmouth design
Bellmouth design
Bellmouth design
Does anyone know of any methods for designing a bellmouth? Are there certain design constraints? ie. the radius is equal to half the radius of the inlet tube. Thanks for the help.
RE: Bellmouth design
What is a bellmouth?
Sorry, I was a little unlcear. Its the top part of a velocity stack on the intake. Here is a pic http://www.todaracing.com/images/engine_toyota_4ag_b.jpg
Its meant to smoothen out the airflow into the engine. Its also known as a trumpet (for obvious reasons). Hope this makes things a little clearer.
I remember reading once that, ideally, the "bell" should do more than just curve away from the mouth of the intake, as seen in the photo you referenced.  I read that the optimal shape is for the edge of the "bell" to curl back on itself rather than simply stop in mid air.  I'll try a (greatly simplified) drawing...
    __       __           _        _
   |   \   /   |   vs       \    /
    \__|   |__/             |    |
The design of the bellmouth affects its design parameters. One for a jet engine intake is designed differently than one for a ducted fan. There is an inlet section, but ducts with bellmouth entrances also can either have a straight discharge, or can taper inward or outwardly.
What do you plan to use it for?
Chasbo
