Back-to-Back Storms
Back-to-Back Storms
Back-to-Back Storms
Has anyone had success modeling back-to-back storms?
I tried entering in "2" in the back-to-back storms calculation setting.  Then, I tried the storm duration setting at both 24hr and 48hr.  The resulting hydrograph still only runs one storm.  Any suggestions?
Chad
RE: Back-to-Back Storms
Forget it.  I figured it out.
When you use back-to-back storms you generally need to increase the calculation time span, otherwise the second storm may fall outside the visible window.  The storm is there - you just can't see.
