Temperature effects for Transformers
Is there a graph indicating temperature vs. efficiency for a 1500 kVA 31500/400 V transformer?
RE: Temperature effects for Transformers
The components of transformer efficiency are primarily no-load {iron} losses and load {copper} losses. Search ieee.org for standards like the C57.12-series of texts.
Else, have you tried contacting the manufacturer of the device?
Only the load losses will vary with temperature significantly.
In steady state winding the temperture difference between ambient and winding will be fairly constant for different ambient temperatures. Based on this you can guess the winding temperature and calculate the losses for different ambient temperature using the temperature coeffcient of the winding material. Using this you can calculate efficiency for different ambient temperatures.
