SW 2003 SP 2.1
SW 2003 SP 2.1
SW 2003 SP 2.1
Has anyone had problems going from SP 1 to SP 2.1?  or noticed  differences (less crashes) that make it wortwhile?
mncad
RE: SW 2003 SP 2.1
I have been using it since it came out and I haven't had any problems. I have found it fixed alot of the problems from SP1.0.
Go look at the SW website and click on the SPR list. Then surf through there and see if there are any SPR's there that may help you. But if your running fine in SP1.0 why do you need to upgrade to SP2.1?
Don't fix it if it isn't broken.
Best Regards,
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
When in doubt, always check the help
RE: SW 2003 SP 2.1
I have seen more crashes since upgrading from 2.0 to 2.1. We had to upgrade because we use equations a lot. I have started to get a message that says “out of system resources” or something like that. Nothing else was changed, Virtual memory the same at 2000 MB and 4000 MB.
Bradley
RE: SW 2003 SP 2.1
Still crashing, still slow.
It's not production ready for the work I do.
