Water 'shaker'
Water 'shaker'
Water 'shaker'
I'm looking for a device who can generate a controled presure pulse in water in a pipe system? Does anyone know if these devices excist? Company's???
Thanx,
Curry (The Netherlands)
RE: Water 'shaker'
Depends what sort of pressure you are looking for, and at what frequency. Sonar systems use them, and so do underwater seismic surveying systems, although I doubt you will be interested in the latter.
Cheers
Greg Locock
RE: Water 'shaker'
The frequency's I'm looking at are not so high as sonar uses. I'm looking at frequenties below 500 Hz.
Pressures are all below 10e5 N/ m2
RE: Water 'shaker'
You basically need a waterproof loudspeaker.  How much power do you need?
Cheers
Greg Locock
RE: Water 'shaker'
A waterproof loudspeaker won't work, although a moving coil transducer (say a Ling shaker) driving a metal piston might do it.  You only need around 20 um displacement to produce a 0.1 GPa plane wave at 500 Hz. A typical sonar transducer won't work as it can't move enough.
Broad Arrow Acoustics
http://home.attbi.com/~pheon
