Inserting views into drawings
Is there anyway to change the 3 standard views (say to top, front and left) that are created when you insert the model into the drawings?
RE: Inserting views into drawings
Open your template and RMB and go to properties and change third angle to first angle. Then save your template.
That changes it from Front, Right & Top to Front, Right, & Bottom.
That's all the choices you have to changing the views that I'm aware of.
Best Regards,
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
When in doubt, always check the help
Also, it depends on the model orientation.  In your drawing, if you have a face that is the top and you want that changed (say to the right), then you have to reassign your orientation in the model.
Ray Reynolds
Senior Designer
Read: FAQ731-376
"Probable impossibilities are to be preferred to improbable possibilities."
In 2003 you can set up templates with Predifined views in them. You can then populate those views with your model.  See page 8-2 of you Whats New document. You can also go under help and in the index type in Predefined.
BBJT CSWP
Scott,
Changing to to first angle projection also changes how the part is rolled for visualization. I'm sure you knew that, but it can be very dangerous if it goes undetected.
Ray
