17-4 Stainless Steel
I am looking for Mechancial properties of 17-4 stainless steel bar stock Condition A. I have searched in many places and have been unable to find this information. Any suggestions as to where I may find this info or does anyone have this information?
RE: 17-4 Stainless Steel
they have tons of info & lots of INCO, AISC etc. publications on Nickel alloys & Stainless steels - design, welding, corrosion, etc.,etc.
http://www.matweb.com/search/SpecificMaterial.asp?bassnum=NCARH0
http://www.aksteel.com/pdf/markets_products/stainless/precipitation/17-4_PH_Data_Bulletin.pdf
http://www.alleghenyludlum.com/pages/products/PDF/17-4.pdf
http://www.cartech.com/
Then click Technical Information then Alloy Category then Stainless Steels then Precipitation Hardenable Stainless Steels
www.framatech.com/pdf/17-4PH-Xu-2554.pdf
www.nrc.gov/reading-rm/doc-collections/gen-comm/info-notices/1992/in92060.html
Condition A (solution annealed) is important, however, in that you should begin the classic 4 hour heat treat from Condition A and from no other condition. Condition A mechanical properties are not typically warranteed or assured by the supplier. If mechanical properties are requested (CMTR's) from the supplier, the material test report will typically include two heat treats eg: H900, H1100 and mechanical tests of these samples from the lot or alloy heat number, to demonstrate adequate performance.
Condition A stock is relatively easy to machine to final shape. Use speeds, feeds, and tools similar to 18-8 stock.
Use of the material, in service, in Condition A is a common misapplication for this material. Because of some confusion in the industry concerning Condition A, it is advisable to heat treat coupons along with any batches of parts and perform hardness and/or pull tests after heat treatment and final cleaning, polishing, etc.
Some users object to the discoloration or pateena formed by heat treat. Also, I have found that the heat treated surface seems more sensitive to galling. Both of these conditions can be aleviated by the electropolish process.
