Autocad 2002 double click
In Acad 2000i and now in 2002 it is possible to bring up the text edit dialog box by double clicking on the appropriate text within a drawing. This appears to be the same with dimensions (again bringing up text dialog box (great for adding extra bits of text to a dimension). However at my new place of work - running 2002, when I double click on a dimension it brings up the 'properties' dialog box.
Is there a setting I can change to make the double click on dimensions bring up the text edit dialog box?
 One of my collegues has this facillity usiing 2002 but doesn't know the setting.
 Can any one help?
RE: Autocad 2002 double click
Try these variables:
dblclkedit ->on
pickfirst -> 1
Lothar
Win NT4.0 (SP6),
ACAD 2000i (SP2), ADT 3.0 (SP3),
OCÈ 5200
besomdave, if you find the solution for this, please tell me.
I tried with the solution gaved by "exit" and DOESN'T WORKING for AutoCAD 2002.
It doesn't take a lot of time to edit MTEXT or single TEXT with a command ED.
Hi bugsfinder,
I don't know more sysvars. Is the double-click property in WIN normal?
Maybe annother usere know the solution for the problem (do You use any applications?)
@naujoke You are right, if You can edit only TEXT and MTEXT, but what about editing:
attibuts,attributs in blocks,blocks,xrefs, mlines, hatches by double-click. Use it and You can stay longer time in bed, because You can work faster…
Regards Lothar
Win NT4.0 (SP6),
ACAD 2002, ADT 3.3,
OCÈ 5200
Hi, besomdave, I've checked this DBLCLICKEDIT (ON) it works on acad 2000 and 2002 too.
Sory, @exit, I didn't mention more command aliases.
two ways:
          1. type dcprops @ command line, "double click properties" set to [off]
          2. express->tools->double-clik properties->[off]
sure hope this helps, not a big fan of double-clik properties.
No one of you understand what besomdave asked.
The question was:
"How to set up the Autocad 2002 to bring up the text edit dialog box whan double click on a dimension line?"
